Bent trac bar bracket - fixed it - now jeep locking up and hesitant
Old Jan 24, 2017 | 10:25 AM
Kawasaki18's Avatar
Originally Posted by PsychoCupcake
Maybe. It is possible to bend a flange but not the mounting surface. I see bent flanges rather frequently on the trail but none of them have had bent mounting surfaces. However with the bent track bar bracket, maybe it was a hard enough hit to bend the whole axle. Best way to check is to remove the axle shaft and measure the angle of the axle flange mounting surface to the axle tube. They should be at 90 degrees.
Ok, I will try that. I will put a small square on my axle tube as well as my shaft.
I hope to god it's just the axle shaft bc this is my DD and coin is very limited.
I appreciate you guys taking the time to help me,
Thank you.
