Best Affordable Winch ?
Old Dec 12, 2014 | 02:01 PM
  #31
tnt008's Avatar
Synthetic rope comes down to the type of terrain you wheel in, IMO. If your gonna be dragging your rope across sharp rock, I'd stick with wire.
Old Dec 12, 2014 | 03:07 PM
  #32
KVJK08's Avatar
I just chose synthetic because I thought it'd be safer to handle and would last long. I would only be using it probably only a couple times a year and won't be doing any rock crawling just yet, just trail rides
Old Dec 12, 2014 | 04:45 PM
  #33
tnt008's Avatar
Synthetic rope is prone to deteriorte when exposed to UV Rays. Ya should buy a cover for ya winch if you want maximum lfe out of your rope. With that said, its much more easier to handle
Old Dec 12, 2014 | 05:12 PM
  #34
auceny's Avatar
I went with a Warn M8000 on Cyber Monday when they were 10% off. ALMOST got a ENGO 9000 but decided against it. This thread is making me second guess my decision. But the Warn already showed up so I'll likely be keeping it.
Old Dec 12, 2014 | 05:44 PM
  #35
Hot94Z28's Avatar
I bought a Engo and it has been good to me. I recommend synthetic rope use it on my ATV and it's really nice. You can get a cover for your winch from Engo for $20.
Old Dec 12, 2014 | 06:44 PM
  #36
holy_crap's Avatar
Originally Posted by FlameRed10
You can do a straight pull with a snatch block. Just run it back to the Jeep.
Not if your closest tree is 90 feet away and you only have 100 feet of winch line.
Old Dec 12, 2014 | 07:31 PM
  #37
DannyMalkin's Avatar
You can use tow straps to lengthen winch line.
Old Dec 12, 2014 | 07:46 PM
  #38
Mad Dog 21's Avatar
Subscribed because I want one as well and y'all's experience is very helpful. Some other questions I would like to ask is there a certain test "lbs" that we should stay close to? I.E. 6-8k for a JK's and 8-10k for JKU's? Recommend accessories like ARB recovery kit? Difference/Pro and Cons between the wire and synthetic line? Thank you.
Old Dec 12, 2014 | 08:10 PM
  #39
tnt008's Avatar
A general rule of thumb that I have read in a couple places is your winch should be at minimum 1.5 times the weight of your rig.
Wire - pros: won't cut as easy on sharp rocks
not affected by UV rays
usually cheaper the synthetic
cons: heavy, harder to handle
can fray and have sharp birms/edges
snaps back when it breaks
Synthetic - pros: will not snap when it breaks, drops dead
easier to handle/lighter
cons: UV rays burn it up/rots
more expensive
Old Dec 13, 2014 | 03:49 AM
  #40
mikeJKUR's Avatar
I have a superwinch tiger shark 9500. You can get one with a steel cable for $350 or with a synthetic rope for $500.
Unlike some of the other winches the solenoid pack is seal so mud, water, road salt will not not be a problem. At a maximum pull of 95000ibs it only draws 340amps. The clutch is a Pull and Turn to disengage/engage.
