Best Affordable Winch ?
Old Dec 13, 2014 | 04:08 AM
  #41
mikeJKUR's Avatar
Originally Posted by KVJK08
Since this would be my first winch ever bought, what do I need to buy along with the winch? Accessories and all.
TJM has a great recovery kit. TJM Recovery Kit Large - Winch Recovery Kit
comes with
19mm bow shackles x2
4,000kg winch extension strap 20m
8,000kg snatch block
8,000kg snatch strap 9m
8,000kg tree trunk protector 3m
Heavy duty leather gloves
Recovery blanket
Old Dec 13, 2014 | 06:38 AM
  #42
DannyMalkin's Avatar
The smittybilt snatch block is only $20 right now on amazon.
Also has anyone bought the new Gen 2 Smittybilt winches?
Old Dec 13, 2014 | 12:53 PM
  #43
tnt008's Avatar
I have the new XRC 9.5. Still relatively new. No problems so far.
Old Dec 13, 2014 | 05:02 PM
  #44
Chemlight's Avatar
Originally Posted by holy_crap
I had a Recon 10500 winch for a couple of years and it performed well for me until I sold the Jeep. For my new Jeep, I'm looking for a winch below $500 with a synthetic line that was at least 9k lbs. I found the Superwinch Tigershark 9500 fit the bill and almost bought one until I found someone selling the 11000 lb model online and bought it from them today. I still think the Tigershark 9500 is the best bang for the buck in that you get a recognized name, enough pulling power for a lightly modified JKU and the safety of synthetic rope for less than $500. To the OP, I think 8K lb rated winches are good for a JK but not enough for a JKU. Using the recommended 1.5 times the GVWR, for the JKU 5500 X 1.5 = 8250 lbs. That means that an 8k lb rated winch doesn't quite cut it, then add aftermarket bumpers, lifts and tires, now your GVWR tops 6000 lbs, so I would recommend that for a JKU, at least 9500 lb rated winch be considered. Also, keep in mind what got you to need a winch in the first place, if you are stuck in mud or sand, the resistance will increase the pull load, I know that using a snatch block will distribute the load, but sometimes that is not an option and a straight pull is required.
Holy crap. Just to comment on your poundage calcs. Um. I have an 8k Warn. Pulls my lifted JKU out like a champ. Snatch blocks etc. All about the mechanical advantage. Generally, people have no idea how to winch properly.
Old Dec 13, 2014 | 08:01 PM
  #45
Nice thanks.
Old Dec 13, 2014 | 08:03 PM
  #46
I agree, a simple snatch block and recovery skills can go a long way in any situation.
Old Dec 13, 2014 | 08:05 PM
  #47
CerOf's Avatar
8k winch and snatch block are good and all....but can be difficult if no easy anchor to tie off to. For convenience sake, single line pull is easier.
Difference in 2-door and 4 is only about 300lbs.
Also sinister who you may be grouped with offroad. I've been through Canada with several range rovers that were 6,000 lbs. I believe my own JKU is around 5,400lbs or so.
I've had to winch an F350 stuck to its frame, used a snatch block with my 9,000lbs winch and it was a slow hard pull.
If you can afford it, don't skimp, go with as much winch as you can afford and fit.
There is a point, IMO, where there's too much. I see no reason for a 12,000 lbs. winch. But hey, you got the $$, go for it.
Sent from some string and a few tin cans.
Old Dec 14, 2014 | 01:03 AM
  #48
JK505's Avatar
I just got a Superwinch 9500 TS and called it a day. It has a pull on it, nothing glorious. I was stuck with a tree nearby, had a winch, and it pulled me out without giving me any problems. Already paid for itself.
Old Dec 14, 2014 | 05:36 AM
  #49
holy_crap's Avatar
That's great, I'm glad it has worked for you, have you pulled yourself out from being stuck on mud or muck using single line? I think you guys are missing my point, I'm talking about circumstances where there are no available winch points nearby to allow for the use of snatch blocks. This happens more times than people think, additional recovery straps are great when you have them, snatch blocks are wonderful when you can use them. Another point is that as the winch line spools, the power rating drops by as much as 42%. Your maximum rated pull is when you're on the first two layers of line on the drum (this means the line all the way out).
Here is a great document. I think it's published by Superwinch, but the basics are all the same for all winches.
http://cdn.shptrn.com/media/mfg/4377...pdf?1289591024
Old Dec 14, 2014 | 06:35 AM
  #50
holy_crap's Avatar
Here are some examples of what I mean.
This guy has a modified Warn 8274, he said he doubled the strength of the winch. The Warn 8274 is a fantastic winch by the way, but you're also going to pay big bucks for it unless you can get a good used one.
https://www.youtube.com/watch?v=kfvEV0V6kvI
For those asking if winch lines break, in this case I would have definitely used a snatch block.
https://www.youtube.com/watch?v=Vr1ByxFi450
This next one is a great example. I don't know what winch he used but it obviously was not powerful enough to do the job single line, you can hear when the winch reached its max and just stopped pulling. This example really illustrates the power of the snatch block too, once the winch reached its max, he added a snatch block and was able to complete the recovery. In this case the recovery vehicle could pull up close enough to serve as the winching point and use a snatch block. Again, this may not always be possible.
https://www.youtube.com/watch?v=nvu1C75VRLA
