best lubricant for suspension parts
I'm going to use synthetic grease for my sway bar links since they have fittings but was curious what everyone use in areas that don't have grease fittings.
Is good old wd-40 the way to go here or should I be using silicone or white lithium spray lube? I plan on hitting the top and bottom seats of my springs as well as the bushings/connection points for the shocks, control arms, track bar etc.
Thanks!
Thanks!
Thanks!
Thanks!
Not sure why you would use a synthetic grease for sway bar links, I would be more concerned with the tackafirers in it. I would use something like the Lucas red tacky. Dry film like said before on other factory bushings.
I was just going to hit up the local hardware store or auto parts store for the spray lubricant. Hopefully they will have some dry film...if not maybe pb white lithium grease. afraid wd-40 will just dry everything out and remove the Grease that is already on there if any
Royal purple has an amazing spray on lubricant. It lasts a lot longer than other similar products. I keep having the throttle shaft stick on and old carb, tried several products that lasted a few weeks. Tried royal purple and it's lasted several years, only one application. I am also a fan of the green grease product. It was designed for multiple application and is very water resistant. Lot of mud bloggers I've talked to swear by it. I've had good luck using it so far using it on bearing and tie rod ends.
I'm using their grease on anything with a zerk. Amazon.com: Royal Purple 01312 NLGI No. 2 High Performance Multi-Purpose Synthetic Ultra Performance Grease - 14.5 oz.: Automotive
Is this it? Amazon.com: Royal Purple 05000 Maxfilm High Performance Multipurpose Synthetic Penetrating Spray Lubricant - 11 oz.: Automotive
