Best paint to prevent rust
Old Aug 1, 2012 | 03:38 PM
jksearles's Avatar
Default Best paint to prevent rust
I have a black jku and I made my first cut into the body for a mod and was wondering what I should use to keep the drill hole from rusting. Is there sonething clear that would work? It's not in a noticeable spot
Old Aug 1, 2012 | 04:21 PM
BIGNICK's Avatar
Ive use a can of spray paint to prevent rust on mine
Old Aug 1, 2012 | 04:32 PM
afpilot82's Avatar
JK-Forum Ambassador
Get some color match touch up paint. I got a small bottle from Quadratec, perfect to brush onto the sheet metal.
Old Aug 1, 2012 | 04:34 PM
kosmos's Avatar
I got some self-etching primer and sprayed a bunch into the top cap and then dabbed a q-tip in that and touched up all
my drill holes with that - if it was the frame I would then put some black rattle-can over the holes.
Old Aug 1, 2012 | 04:35 PM
DV3's Avatar
DV3
It depends on how big the area you need to cover is. If it's a fresh drill hole or a bare edge from a cut that's not to big, any type of paint to cover the bare metal up should be suffice.
Any larger and I would recommend and etching primer for the bare metal and then paint.
Old Aug 3, 2012 | 06:30 AM
2acrawl's Avatar
i gotta be a SMART ASS. Most paint works in SUNNY california here.
Old Aug 3, 2012 | 06:48 PM
Jeeper'08's Avatar
Anything RUST-OLEUM?
Old Aug 3, 2012 | 07:52 PM
deathboyardee's Avatar
Anytime I go to bare metal on the body I always prime with a "name brand" primer and follow up with the Mopar color matched spray paint to top coat even if it's in a hidden area. If it's just a small spot you can spray some on a paper plate and Q-Tip it.
