Bestop Trektop nx instal help!
Old 12-01-2012, 03:59 PM
Powderburn's Avatar
Default Bestop Trektop nx instal help!
Trying to instal my new trektop and its not goin to good. Seems to be a big gap on the front left and right sides of the windshield
And the zippers for the rear window are no where close the the side zippers. Its almost 6" on both sides
Any ideas or help would be awesome
Old 12-01-2012, 04:55 PM
Lando's Avatar
I had the same gap with the rear.window... I installed when it was 95 degrees outside and it was difficult. Make sure the vinyl is not cold or it will be very hard to stretch into place.
Old 12-01-2012, 05:04 PM
Patman's Avatar
Take off the rear windows and flip the top open. Then:
1. start the top zipper (2 inches)
2 start the window zippers (2 inches)
3. then tuck the window panels in, starting with the door surrounds and working your way around to tailgate.
When new, these tops are a pain in the ass to install, especially when cold
Edit - Is your front gap with the latches closed? Mine has a gap, but I don't have any leaks there
Old 12-01-2012, 07:25 PM
Powderburn's Avatar
Thanx guys. Does it get any easier to put on the windows?
Old 12-02-2012, 02:28 AM
OH9JK's Avatar
It will loosen up slightly over time. Big factor is the outside temperature though!
Important steps are to only start each zipper 1 - 2" and then work your way around once you have them all started.
The top needs to be this tight since it does not have a frame.
Old 12-02-2012, 05:32 AM
Atch's Avatar
First time installing should be done outside in the hot sun.
Old 12-02-2012, 06:21 AM
Patman's Avatar
Yep, it gets easier. Once they are on for a few days, everything will stretch and fit better. Sitting in the sun helps
Old 12-02-2012, 09:38 AM
Powderburn's Avatar
I installed it in Houston friday late afternoon. Was about 70 out. But no sun
Old 12-02-2012, 10:02 AM
Jersey_Devil's Avatar
I had the same problem in 90° weather..... If u just play with it, and figure out which way works best for u..... I just start the zippers before pulling the top tight then after the top is snapped into place I zip the windows up.... Still hard to do but not bad.... Good luck!
Sent from my Samsung Galaxy Tab 10.1 using Tapatalk 2
Old 12-10-2012, 11:22 AM
Powderburn's Avatar
Got it all zipped up finally. (Was out of town for a week) and this happened...
And i woke up to find sunlight coming through the roof...
Guess im calling bestop
Quick Reply: Bestop Trektop nx instal help!
