BFG 285/70/17 rubbing
Old Jul 2, 2011 | 02:47 PM
jay8ird's Avatar
Default BFG 285/70/17 rubbing
Had BFG's installed the day I bought Jeep along with 2" spacer lift. Tires rub at full turn. Can't even get in parking spaces without 2 try's. Are correct backspace wheels safer than wheel spacers?
Thanks
Jay
Old Jul 2, 2011 | 03:00 PM
Battlefrog's Avatar
You can run 1.5" Spidertrax wheel spacers with no issue. I have aftermarket rims with 4.5" BS and still run spacers. If you don't mind the factory rims, go with the cheaper solution.....
Old Jul 2, 2011 | 03:02 PM
Battlefrog's Avatar
As for safety, I'd say at least 60% of the users on this forum run wheel spacers...
Old Jul 2, 2011 | 03:35 PM
cbeas's Avatar
I've had Spidertrax spacers on 2 different Jeeps & never had an issue.
Old Jul 2, 2011 | 03:36 PM
nthinuf's Avatar
I dint know what size they were and if they provided better flex off road or not.
Haven't seen any reports of quality spacers being unsafe, but rims with the proper backspace are 'easier'. Spacers have more parts, so more points of failure and require more maintenance. And a lot of shops will not mount/rotate tires if you are running them.
Old Jul 2, 2011 | 10:44 PM
Quentin_T's Avatar
What are you rubbing on??? Check to see if it's just that ugly plastic air dam.
Wasn't long before I tore that off.
Old Jul 2, 2011 | 11:03 PM
cppower's Avatar
The cheapest fix is to add a couple of washers to the steering stops.
Unless you added new front swaybar liinks, then you will need to decrease your wheel backspacing.
Old Jul 2, 2011 | 11:45 PM
AK4Dave's Avatar
I figured with the cost of the spacers I might as well put that money towards some nice wheels instead. I have 285/75/16, no lift, and don't rub with 4.5" of bs.
