bigger rubber to stock rim
i don't see a whole lot of siping on those muds...you might want to have a tire shop do that for you...my MT baja-belted had a similiar lack of siping....and i had some real bum-pucker moments on the road.
Eternal ***erator
http://www.discounttiredirect.com/di...TiresBySize.do
http://www.titantalk.com/forums/tita...nkook-mts.html
http://www.dodgetalk.com/forums/showthread.php?t=133749
http://www.fjcruiserforums.com/forum...o-mt-rt03.html
http://www.toyota-4runner.org/showth...oto=nextoldest
Related question: If you were to put 305/70R17s on a Rubicon w/ a 2" lift while still using the STOCK Rubicon wheels w/o spacers, would they fit?
Not a good idea. 305 tire is 50mm (2 inches) wider than the stock 255 tire. That will put the inside edge of the 305 tire 1 inch closer to the control arms on the suspension. On my stock rubicon there is only 1' clearance between the stock tire and the upper control arm in the rear so a 305 tire will rub continously.
