Bilstein Leveling Shocks?
Old Oct 21, 2016 | 08:12 AM
flyfishingjk's Avatar
Default Leveling kits
I am looking to put something around a 33" tire on my jeep, I am pretty sure there is no lift to possible 1 inch. Anyway any suggestions on AT tires and sizes? I don't want to go over a 33 due to the trails I will be going down to fish.
Old Oct 21, 2016 | 08:35 AM
Carbon's Avatar
With 33s you should be fine with stock suspension. You may want to get some 1.5" wheel spacers if you're gonna run a 12.50" wide tire though.
Old Oct 21, 2016 | 09:16 AM
patricks99's Avatar
Veteran: Marine Corp
Should be fine stock with 33s, if you felt you need a little extra clearance you could get a 3/4in spacer front and back from daystar.
Old Oct 21, 2016 | 10:30 AM
dbmorris's Avatar
I just went from my stock 255/75-17's on my Rubicon to GY Duratrac 285/70-17 and live then so far. My has a 2-3" lift (still not for sure on what it has yet) with no rub or problems. They spec to about a 33 but measure at 32.5 installed. Smooth and aggressive enough. Should check them out.
