What's my next step
Old Oct 21, 2016 | 09:26 AM
Kempo x Ted's Avatar
Default What's my next step
13 jk 2Dr with volant tbs and k&n filter stock intake 1.75 leveling kit and 285/70/17s on stock wheels with spacers also front and rear bumpers by exstream terrain and side armor from quadratec. I have not done any programming with a flash Pac and not sure what to do or not it is my dd. Any suggestions would be appreciated. Thanks
Old Oct 21, 2016 | 11:42 AM
Chuck-The-Ripper's Avatar
Put gasoline in it when needed, change the oil every 3000-5000 miles, and drive it.
Old Oct 21, 2016 | 12:14 PM
Smudgeontheglass's Avatar
Probably would be a good idea to get the tire size programmed into there. Will help with shift points if you're an auto as well as keep your speedometer correct. Really everyone goes about making their own mod list so where you should go is based on your driving and wheeling habits.
Since I purchased my JKR My steps so far have been:
1. Recovery gear
2. LED Headlights (+AEV Procal for DRLs)
3. Bumpers, winch, sliders, CB Radio
4. Suspension (2.5" coil lift)
5. Tires (35s, track bars, geometry correction)
6. Front Truss and gusset
7. Lighting (pillar pods, 50" light bar, associated switchgear)
In between I got a grill mesh, grab handles, fitted floor mats. Next on my list is going to be skid plates because both my crossmember and gas tank skids are bruised.
If I were you, I would go for lockers / gears. If you have 3.73 gearing you're completely fine with the 33x11 tire but a part time or selectable lockers would be a good idea.
Old Oct 21, 2016 | 01:23 PM
jordy's Avatar
Loved
Community Favorite
You forgot the part about sitting back and counting money and putting it in the bank.
Old Oct 21, 2016 | 02:15 PM
Thanks for the feed back I do need to find out what the gears are, it's a sport with Dana 30s so lockers might be next
