Binding/popping sound RCV
I have a Pro Rock 44 with RCV shafts. I got hung up on a concrete divider about 5 inches high. Now I have a intermittent binding/popping sound coming from the drivers side CV joint area. There is no impact damage. I took the wrong angle and had to gun it to get over. I also have a 5.7 Hemi and I had to use a bit of power to make the jump. I was in 2wd. I pushed the boot off and I don't see anything obvious wrong.
Thanks for any feed back.
Clicking??? If so... probably the star cage.
Call them, tell them what you got and they will send out a new item for you. The warranty is the best I've ever seen and I've used it three times so far.
Thanks for the info. It seems strange they would break by just jumping concrete. I had the shafts in my factory housing at the JKX in 2012 and had no problem. I replaced the snap rings when I put them in my ProRock. I must have done something wrong.
This may not be what's wrong, you need to take the shaft out and inspect.
