Black Lug Nuts..
Quadratec sells black lug nuts for $1.99 each. Not sure if you need something special for steel but it's worth a call.
http://www.quadratec.com/products/92806_302.htm
Do them on the ground, one at a time. If you do it while lifted your tire will spin when you go to torque it unless you have someone hitting the brake.
(BTW I have officially seen every question possible on this forum
Anyway thanks for the response. Ill do it with em on the ground.
I just put a set on from Gorilla yesterday. The finish didnt scrape or chip when i did, so i'm happy. As far as i know, the wheels are still connected to the JK, so they appear to work.
When you put on wheels, don't forget to torque to around 95 and start off at lower torque going through three times in a star pattern.
Yeah I just ended up going to sears and getting a socket for em. Used that with a breaker bar and torque wrench on them. Man were the stock ones shot. Tightened em all to 100 ft lbs.
