blown bilsteins
Old Aug 6, 2014 | 04:46 PM
Jackedup's Avatar
Default blown bilsteins
ok, so I went into the garage tonight and noticed some spots on the cement under the left rear shock (bilstein 5100). The shock is all black and oily at the bottom. I loosened the rubber boot and there is a light stream of clear liquid running down the shaft . the shocks have been on for 36000 miles . can anyone suggest some shocks that are better then these but not 200$ each. I have a 3.5 "AEV lift but want to change to the 4.5" springs and bump stops so I need shocks that will work with both heights. HELP!!!!!!!!!! asap cause I'm going to jeep week in 1 1/2 weeks
Old Aug 6, 2014 | 06:41 PM
20JK10's Avatar
Rancho RS9000XL are pretty popular.
Old Aug 6, 2014 | 07:19 PM
roscoj's Avatar
Pretty sure billstien has a lifetime warranty. I think you can send them in for new or rebuilt but that might take a while and you need them in a week and a half. Might be cutting it close. But it's worth a try.
Old Aug 6, 2014 | 08:05 PM
NewOldSchool's Avatar
Same think happened to mine. Only 20k miles. Had them replaced under warranty. Give the company a call.
Old Aug 7, 2014 | 01:09 PM
stefel22's Avatar
same here, replaced under lifetime warranty If you had a shop install your lift bring it back to them and have them order the shocks so your jeep isn't laid up
Old Aug 8, 2014 | 08:17 PM
Jackedup's Avatar
thanks for the reply's . I ended up contacting AEV and they are sending out a new one
Old Aug 9, 2014 | 02:39 PM
gunbo75's Avatar
Yes they do have a warranty but they want you to return the ones you have that are bad before you get the new ones.
