Blown motor 42,000
Old Mar 19, 2012 | 04:10 PM
ronjenx's Avatar
Originally Posted by ptwilson
Like "Business Major"?
Sorry ... That was wrong.
I wasn't thinking in that direction....but that's funny!
Old Mar 19, 2012 | 04:18 PM
robarham's Avatar
Originally Posted by Lomax-dtl
What should I do, I'm shocked it died so young
This blows! But I feel your pain... My motor blew last weekend at 89,000. No warnings at all. I was just driving down the road and the engine went to knocking. I was able to get it back to dealer before it completely seized. I hope everything works out for ya.
Old Mar 19, 2012 | 04:57 PM
carolinajk's Avatar
could you have run it hot ? whAt color smoke ? blue ? white ?
Old Mar 19, 2012 | 05:00 PM
scooby snacks's Avatar
Get it to the Stealership... seems like it would be under warranty with 42K miles.
Old Mar 19, 2012 | 05:02 PM
carolinajk's Avatar
does it have coolant in the radiator ck the oil and see what level and color it is . did you smell oil when it happened ?
Old Mar 19, 2012 | 06:05 PM
Lomax-dtl's Avatar
Grey from pipes and under the hood
Old Mar 19, 2012 | 06:06 PM
Lomax-dtl's Avatar
Originally Posted by cowboybob
What year is your JK?
2009......
Lomax-dtl's Avatar
Easy there
Old Mar 19, 2012 | 06:08 PM
Lomax-dtl's Avatar
It's low but not under filled. But the oil has metal pieces on the dipstick wtf?
Old Mar 19, 2012 | 06:17 PM
carolinajk's Avatar
you need to. k under hood and verify all your fluids look at your oil level close if it appears milky and or level is very high could be coolant from a head gasket leak or dMaged head if. oolant got in your oil it could cause internal failure from no lube your past oil consumption could also indicate a cylinder with bad rings and that condition couldve resulted in a damaged. inder and or piston coming apart . a seized bearing is also a posibility from either lack of oil or coolant in the case .et us know what u find
