Blown motor 42,000
Old Mar 19, 2012 | 06:19 PM
  #21
carolinajk's Avatar
Originally Posted by Lomax-dtl
It's low but not under filled. But the oil has metal pieces on the dipstick wtf?
you either dropped a piston or spun a bearing im bettin on the latter
Old Mar 19, 2012 | 06:22 PM
  #22
DesolationMania's Avatar
Seems like it should still be under warranty. If not, then grey smoke doesn't suggest a blown head gasket, usually that is more white. Start with the easiest/cheapest things first. Does it have a trouble code? If so, what is it? Does the oil smell burned on the dipstick? Pull the spark plugs, what do the electrodes look like? The troubling part is the metal you are seeing on the dipstick. Change the oil and note how much metal you see in the oilpan. Does the oil smell burned? I would do a compression check of each cylinder. Check for cracks on the head and the engine block itself. Put something light colored under the engine overnight and check for leaks. Problem is I don't know what your capabilities are, what tools you have, engine knowledge, etc. These are just some of the starting points.
Old Mar 19, 2012 | 06:53 PM
  #23
Lomax-dtl's Avatar
I just got done rebuilding a 5.9 with my truck. It had the same thing happen and it was a bad cylinder. This could be different though.
Old Mar 19, 2012 | 07:21 PM
  #24
ronjenx's Avatar
Easy there
Like I said, I wasn't thinking that. Someone else brought it up.
Old Mar 19, 2012 | 07:28 PM
  #25
BKGM Jeepers's Avatar
What should I do, I'm shocked it died so young
I know a guy who's got one for sale that he just pulled from his JK in a hemi swap. It has 20K miles on it but we're in CA....
Old Mar 19, 2012 | 07:40 PM
  #26
nictac1's Avatar
Originally Posted by scooby snacks
Get it to the Stealership... seems like it would be under warranty with 42K miles.
ouch.......
i dont recall seeing what interval the oil was changed....otherwise look for a rockershaft on the pass side.......
but of course jk owners take care of their vehicles......visit the dealer you've been loyal to & they will take care of you........if they don't call chrysler
Old Mar 20, 2012 | 04:18 AM
  #27
JPop's Avatar
Metal in the oil pan and your upgrades are going to make it pretty tough to get the dealer to step up on this one. The red flag as I see it is the custom dual exhaust. Too big and it can lead to carbon build up on exhaust valves, clogged EGR and other issues. If the cats were removed, even more potential issues and a tuner that was not designed to work with the exhaust as situated.
If you could provide some details on your exhaust, that would be helpful. If as I suspect your exhaust has been modified you're probably not going to have a lot of luck at the dealer and should just begin your quest for a used motor. If it's somewhat in line with proper cylinder evacuation and exhaust velocity, you might still have a shot.
Old Mar 20, 2012 | 04:23 AM
  #28
Rule18's Avatar
Originally Posted by ptwilson
Like "Business Major"?
Sorry ... That was wrong.
Wow... Rough crowd. . .
Old Mar 20, 2012 | 09:23 AM
  #29
Lomax-dtl's Avatar
I highly doubt they will do this and that why I though I would post in here. I think I should just go find a used 5.7
Old Mar 20, 2012 | 09:34 AM
  #30
prelucir's Avatar
Veteran: Navy
Time for a Hemi.
