on board air opinions
ready to add an on board air need opinions on systems and how you mounted them other than arb. i already have an arb with the master cylinder mount that just runs my lockers. want to have a totally seperate system for airing up my 37s and occasionally running air tools. looking at the vair constant duty. what are you guys running?
exactly. Run a separate solenoid specifically to fill the air tank from the ARB compressor. You don't need to have run your lockers while youre airing up.
unless i run the dual arb the single doesnt have the output im looking for i already have the small arb and works perfect for the lockers. so instead of replacing it with a different higher output compressor i would rather leave it alone and just add another system.
