boat anchor
Old Jan 25, 2011 | 05:33 PM
bchoate79's Avatar
Default boat anchor
cant figure it out had gears put in my jeep about a week ago took it to off road where house in el cajon. I drove it for about five hundred miles so taking it easy going about ten miles at a time then at about five hundred pushed it about twenty or thirty and smelt some thing hot but not likr gear oil i think hard to tell when your going just would get alittle wif every now and then now it feels like theres a boat anchor tranny shifting weird i figured because it was under a load because gears burned up but took to offroad where house today and they said gears where fine i have no idea jeep only has 2000 miles really dout trannys a problem any thoughs
Old Jan 25, 2011 | 05:34 PM
wayoflife's Avatar
JK-Forum Founder
did you calibrate your speedo to match your tires and gears? if not, your shift points are most likely off.
Old Jan 25, 2011 | 05:37 PM
SoupSandwich's Avatar
Im not one for pointing out bad grammar and use of puncuation (SP?), but holy hell!
Old Jan 25, 2011 | 05:38 PM
wayoflife's Avatar
JK-Forum Founder
honestly, i was thinking the same thing but decided to let it go
Old Jan 25, 2011 | 05:49 PM
T&ERun's Avatar
Probably was typing on a cell phone while driving.
Old Jan 25, 2011 | 05:54 PM
bchoate79's Avatar
haha no my grammar just sucks but yes programmer is installed.
Old Jan 25, 2011 | 06:00 PM
cj8driver's Avatar
ck the front vent coming off the diff and see if you have a slight amount of gear oil coming out if its overfilled it will seep out when the oil warms
B
Old Jan 25, 2011 | 06:02 PM
Pluke the 2's Avatar
check the diffs, check the tranny fluid, and please throw a transmission cooler on that thing!!!!!!!!
Old Jan 25, 2011 | 06:07 PM
bchoate79's Avatar
I thought it was rear diff because front was worm to touch and rear you couldn't even put your hand on but manager at shop said that was normal. I pretty sure it should be same since front spins same as rear since i don't have locking hubs maybe I'm wrong though.
Old Jan 25, 2011 | 06:38 PM
mkjeep's Avatar
The rear when in 2wd will always be hotter than the front because its under load.
The rear does get hot mine was was in the 140-150 degree range after gears, shop said it was within spec.
