Body Lift Raises Side Steps?
Old Sep 18, 2009 | 02:07 PM
redex's Avatar
Default Body Lift Raises Side Steps?
I had a quick question...
If i install a 1" BL like daystar's would that raise the side steps as well or would the side steps be the same height?
(Don't have a JK yet so i don't know if its frame mounted or body mounted)
Thanks!
Old Sep 18, 2009 | 02:13 PM
mueller433's Avatar
If the daystar lift works the same way as the MORE body lift then the answer is no. For these lifts you add the spacer and then add longer bolts. Most side steps attach to the frame not the body.
Old Sep 18, 2009 | 02:16 PM
Originally Posted by mueller433
if the daystar lift works the same way as the more body lift then the answer is no. For these lifts you add the spacer and then add longer bolts. Most side steps attach to the frame not the body.
they are mounted to the body so unless the body lift comes with something to keep them the same but you'd want them to follow with the body
Old Sep 18, 2009 | 02:17 PM
Originally Posted by redex
i had a quick question...
If i install a 1" bl like daystar's would that raise the side steps as well or would the side steps be the same height?
(don't have a jk yet So i don't know if its frame mounted or body mounted)
thanks!
if you don't have a jk this is the worst of your worries
Old Sep 18, 2009 | 02:18 PM
MOPAR sidesteps are body attached, or at least mine are so the answer would be "yes"
Old Sep 18, 2009 | 04:06 PM
mudslingin44's Avatar
if you have a x or sahara with factory steps,they will go up with the body lift because they are attached to the body of the jk.i dont know about rock rails tho because i have a sahara
Old Sep 18, 2009 | 05:37 PM
aldaman's Avatar
I have a 1" BL & the mopar enhanced rock rails...They are mounted to the body & not the frame, so yes it will get raised...Here's a pic for reference....
Old Sep 18, 2009 | 07:16 PM
redex's Avatar
hahaha
your right! my worst worry is hurry up and selling my honda fit! :P
Anyone want a 2008 honda fit 5spd Manual?
