brake lines rubbing
Old Jan 12, 2012 | 11:20 AM
samhardy2008's Avatar
Default brake lines rubbing
Ok was checkin stuff out under my Jk today and noticed my brake lines are rubbing the rear sway bar linkage,I have a 4 inch superlift lift kit.....what would be a good fix? I thought about bending the lines but don't really want to eff them up
Old Jan 12, 2012 | 11:24 AM
FoxRacingJMC's Avatar
You can bend the metal lines, just make sure if you bend them that if/when you flex they won't rip off or cause more damage. Also don't bend them too much that the actual line will weaken or snap. Nothing worse than screwin' up your brake lines. Some people fab up some brackets to extend the factory brackets. Just some DIY stuff will fix the problem, nothing to worry about too much - YOU CAN DO ITTTTTTTTTTTT!
Old Jan 12, 2012 | 11:32 AM
Well see I just don't wanna bend it really cause there's a spot where it's worn down pretty good not to the point where there's a hole but I would hate to break it man that'd blow
Old Jan 12, 2012 | 11:43 AM
texwillys's Avatar
Sam, it's easy to bend those brake lines too far and kink them. Can you bend the bracket instead? I was able to clear my brake lines that way.
Old Jan 12, 2012 | 12:11 PM
did you use just a pair of channel locks or something?? i was thinking bout trying that earlier just didnt know if anybody else did try it and had success but seeing that you did i think im gonna have to try it!! appreciate it man, did you end up getting your new lift on i assume??
Old Jan 12, 2012 | 12:17 PM
Who me? Sure did.... working on getting before and after pics up this weekend.... just hard with work and my 3 month old daughter...
Old Jan 12, 2012 | 12:44 PM
Lol no my last response was meant for Brian, and I found out the issue was the drop down bracket that was put on actually made the brakes contact the sway bar so I pretty much remove bottom half of bracket and only used top half worked like a charm lol!
Old Jan 12, 2012 | 01:02 PM
Well shitballs now I think it might not have enough room to flex without ripping off
Old Jan 12, 2012 | 01:11 PM
Ok so im thinking I need longer brake lines any suggestions? The original drop down brackets are a no go
Old Jan 12, 2012 | 01:48 PM
OverlandJKU's Avatar
Northridge used to have a package deal of 4... Not sure if they still do...
