Brake Pads - What do you like best and why?
Powerstop Z36 JK Wrangler P/Ns.
Stock Front: Z36-1273
Stock Rear: Z36-1274
Mopar BBK Front: Z36-1084
As an FYI, if you shop on Amazon they seem to have the description incorrect for the rear pads. The description says "Front" pads for the Z36-1274. Although with my JK in my Amazon garage it does confirm the link below fits the rears.
https://www.amazon.com/dp/B00JGRXFKK/?coliid=I6A7G8JLEUNP2&colid=20TXEAD6EBPRA&psc=0&ref_=lv_ov_lig_dp_it
That threw me off, and had to visit Powerstop's website to get a double confirmation of the front and rear P/Ns.
https://www.powerstop.com/product/po...RANGLER&p=Rear
https://www.amazon.com/dp/B00JGRXFKK...v_ov_lig_dp_it
Doing PM today oil change, grease, tire rotation and noticed my right rear brake pads are wore down to about an 1/8 of an inch, the driver side still has a lot of meat so it appears RR is doing all the braking. I installed Power Stop Z16 evolution brake pads PST16-1274 with the Power Stop rotors PSTAR8382XPR only 10,604 miles ago. I changed the RR caliper back in 2013 due to seized. I just can’t believe that the pads on the right hand side would wear down so quickly. I have a manual and use my clutch to do most of the braking. Rolling on 35 Cooper STT pro. Just wondering if a better pad or maybe both my calipers should be changed out. Before I buy another set of pads does anyone have a recommendation.
Good point with possibly LH caliper not functioning properly. I guess I will start looking for rear brake caliper upgrade that will still work with my power stop rotors.
Looks like I’m going to try the Power Stop brake calipers and Z36 pads, Extreame Terrain has for $293.00, any other suggestions before I pull the trigger and order these?
I'm still liking the Raybestos EHT pads. Regarding the worn rear pad, in addition to checking/comparing how hard the rear caliper pistons are to compress before installing the pads -- Suggest cleaning the rear wheel speed sensors, especially if you have noticed the traction control dash light flicker when it wasn't a slick road surface.
The sensors are held by one bolt, and the connector has the usual red lock-tab that must be slid before pressing the release. The rear sensors are exposed in the parking brake area, and metallic dust particles eventually collect on them that can cause the sensor to misread pulses from the reluctor ring on the axle and apply the brake to one wheel momentarily. Just wipe off the sensor and re-install.
How long do you really need to change Jeep's brake pad? I bought mine before at Mopar parts from https://www.jeepsareus.com/sku/v1010868ad.html. Is there a more premium pad?
