BROKE Somethin
Old Aug 18, 2012 | 06:53 PM
C0mf0rt's Avatar
Default BROKE Somethin
Had a great day climbing and broke a few things. I'm only worried about one.
What's the rubber boot between the pitman arm and the trackbar called? Can you recommend any good aftermarket replacements?
Old Aug 18, 2012 | 06:55 PM
Cfitz22's Avatar
Tie rod ends.
Old Aug 18, 2012 | 07:02 PM
C0mf0rt's Avatar
Originally Posted by Cfitz22
Tie rod ends.
CORRECTION.... Pitman arm and drag link..... See the first post...
Old Aug 18, 2012 | 07:29 PM
D_engel's Avatar
get a moog replacement for a dodge ram. Beefy, cheap, and its a direct replacement of our stock TRE. I dont know the part number off hand, but a quick search should help you out.
Old Aug 18, 2012 | 07:37 PM
Curiosity's Avatar
This.
Got mine at advance auto with a 35% off coupon.
Your part number is ES3624
its cheap and it is an upgrade over stock (beefy and it has a zerk)
Old Aug 18, 2012 | 08:29 PM
4x4Laoch's Avatar
It is simply a dust cover. Helps keep dirt and other small particles out of the pitman arm ball socket. You are fine for now, but I suggest trying to find the boot separately or getting a pitman arm for a spare for when the other one fails.
Old Aug 18, 2012 | 08:31 PM
c17loadmaster's Avatar
Originally Posted by Curiosity
This.
I second that. I bought the same one. Factory was crap. Got mine at advance for 20 something bucks. Be ready to recenter your steering wheel or your ESP will go berserk when you hit 40 mph.
Old Aug 18, 2012 | 09:15 PM
D_engel's Avatar
why would you get a spare pitman arm?
Old Aug 19, 2012 | 12:26 AM
C0mf0rt's Avatar
Thanks guys. You just saved me tons of time searching. One last question. Don't you need a special tool to remove/replace it? I've never swapped tie rod ends out.
Old Aug 19, 2012 | 07:15 AM
You will need a tie rod removal tool. Aka " the fork" you rent one from autozone, or buy one from them. Soak your threads in pb blaster or Wd40 and you will be set. It is pretty simple. Hardest part is centering the steering wheel so your ESP doesn't go nuts.
