Broken Axle Shafts
Old May 3, 2010 | 08:49 AM
  #21
Northridge4x4's Avatar
Sponsoring Vendor
I have never built front edns to have a weak link in them. And honestly we rarely see a blown up ring and pinion.
The way I look at it is BUilt it without and weak links and if it break that is your jeep telling you that you need a bigger axle. The 30 or 44 has reached the end of its life to say.
This topic is pretty high up on the most argued on the internet.
U-joint failures usually take out the ears of the axles.
Beef up the u-joint and you may take out the axle which may take out the Carrier.
Beef up the axle and you may break the ring and pinion.
And so on . We can argue for ever about this I have seen all of this happen.
Like I said I prefer to take my chances breaking a ring and pinion.
David
Old May 3, 2010 | 12:35 PM
  #22
m(a)ce's Avatar
Thanks everyone for the info. Now I'm getting a clearer understanding of the two sides.
It seemed like there was conflicting ideas out there and I could never imagine Jeepers (or anyone on the internet) having strong, differing opinions
Old May 3, 2010 | 01:37 PM
  #23
synscan's Avatar
Originally Posted by lang1864
i seriously doubt they will cover it. Nice break though!
Thanks, once I got unstuck and got back on pavement that was actually my first thought. Though I was less enthusiastic today pulling out the busted bits.
Originally Posted by Under Dawg
To the OP -> can you describe the conditions at the time of the break? I see snow, obviously, but were you climbing or churning through deep snow and hit something? Most axle breaks are due to shock load, e.g. front wheel spinning free in the air and coming down/gaining traction all at once. I'm just interested, maybe others can learn from the little mishap?
UD
Got high centered on some unexpected snow (def. need a lift) and in my attempt to get free I kept getting more and more off the trail. I had my wheel jacked to the left and got a little brutish with the gas. Upon further reading it seems a turned wheel is a definite no-no.
Originally Posted by CA-JK
It looks a lot worse than it really is. This really is an easy fix and I highly recommend you learn to pull your own shafts
I did today. I could tell on the phone the dealer was a jackass and wasn't going to cover it. I pulled the two shafts and plugged the hole so I can at least limp it to the train station. I'll be ordering replacements today.
Originally Posted by Suffolk JK
IMO, go with OEM units or Chromoly.
I've been looking all over for OEM parts and the only ones I've found are more expensive than the Ten Factory ones from Northridge. So unless someone has a decently priced place for OEM parts I'm leaning that way.
Originally Posted by Sethc84
The Jeep 'Guru' says so.
Hate to be a sack rider, but that was my thought. wayoflife has show time and again he knows his shit.
Originally Posted by Kasper
The high wheel spin and turning are hard on the joints, caps fall off and failure....
Haha, where were you on Saturday?!?
Thanks for all the feedback guys. I've learned a valuable (and only mildly expensive) lesson this week.
Old May 3, 2010 | 01:46 PM
  #24
synscan's Avatar
More pics of the carnage. The inner shaft seemed hard to get out so I was relieved to see that the splines were still in good shape.
Old May 3, 2010 | 04:10 PM
  #25
Suffolk JK's Avatar
actually, i don't think you can use the SBS in an axle with magnums but i know you can use it on any 30 or 44 front axle. trust me, i have used my plug to help others out before
Ahh, thought they went hand in hand, could've swore when I read the product release it said you needed Magnums for the plug. Cool, something to add to the list.
Old May 3, 2010 | 04:13 PM
  #26
Suffolk JK's Avatar
2 out of 3 times I broke, a few of the inner splines had a twist to them. They shaft just didn't pull out, had to slam the hell out of it with a 3lb sledge and a prybar. Could only imagine the splines not twisting and having that load on the carrier...just me.
