broken ball joint?
Old Mar 17, 2013 | 04:53 PM
Taurance's Avatar
Default broken ball joint?
hey,
I went to install new ball joints today and I seem to have bent one of my lower ball joints... my question is it bent or did it just move? these are new alloy usa ball joints. any suggestion if I did bend it? Thanks.
Old Mar 17, 2013 | 05:13 PM
hagausaf's Avatar
bent the one you were trying to remove or the new one you were trying to install?
Old Mar 17, 2013 | 05:42 PM
ronin2120's Avatar
Vet Army
the bottom ball joint should pivot hopefully you didn't bend the stud
Old Mar 17, 2013 | 06:33 PM
Taurance's Avatar
well one looks straight and the other was slanted so I assumed bent. how can I pivot it straight again?
Old Mar 17, 2013 | 06:38 PM
dognights's Avatar
most likely bent the C not the ball joint if that is the case. Id check both either way thou
Old Mar 17, 2013 | 06:44 PM
ronin2120's Avatar
Vet Army
Can you take a pic that would help out a lot more
Old Mar 17, 2013 | 07:29 PM
Tripletsi's Avatar
I would guess you just moved it, it would be extremely difficult to bend that thick of a stud. Remember the bottom bj does pivot, it will be tight since its brand new so just push it back to bolt on your hub assembly.
