broken front coil spring?
Old Mar 29, 2009 | 07:55 PM
capt scotty's Avatar
Default broken front coil spring?
I was preping my JK for Moab and Noticed my front coil spring is broken. It is rusted on the broken end so it has been that way a while. Has anyone else broken a spring? OEM oR aftermarket
Old Mar 29, 2009 | 08:01 PM
wayoflife's Avatar
JK-Forum Founder
holy cow, it's rare but yeah, i have seen it happen before. i see that you have a TF 4" lift. did you make sure to install both the upper and lower bump stop extensions? got any pics?
Old Mar 29, 2009 | 08:12 PM
I haven't taken any photos. The lift was prof. installed (not by TF) They are only 10 mins away. So I will have TF check it out tomorrow. Broke about the second turn up from bottom. I'll keep you informed.
Old Mar 29, 2009 | 08:16 PM
wayoflife's Avatar
JK-Forum Founder
well, if one of the two bump stop extensions is not installed, you most likely over compressed your coil. typically, this just results in a coil that does not return to full height but in rare cases, it can fatigue the wire to the point where it can break. of course, you could just have a coil that had a brittle spot on it. either way, i have no doubts that TF will take care of you.
Old Mar 30, 2009 | 10:38 AM
I just got back from Tera Flex. They are replacing it with absolutely no hassle.
Even though they did not do the install they are standing behind thier product. As they always have for me. They will replace it tomorrow.
Old Mar 30, 2009 | 10:40 AM
wayoflife's Avatar
JK-Forum Founder
sweet - glad to hear they are taking care of you. did you ever find out if both bump stop extensions were installed? i'd really like to know for my own purposes. also, did you happen to get any pics?
Old Mar 30, 2009 | 10:58 AM
Both bump stops are installed correctly. Looking closer it looks like a flaw in the steel. here is a photo.
Old Mar 30, 2009 | 11:01 AM
Offroadme's Avatar
wow thats crazy i have never seen one of those break. there is a first time for everything though., TF is great. They have helped me out BIG time in the bast they DEF stand behind there products
Old Mar 30, 2009 | 11:20 AM
TeraFlex's Avatar
Sponsoring Manufacturer
In the last 10 years, TeraFlex has only seen 2-3 coils fail like this. Typically when a coil fails, it's fatigue type.
Old Mar 30, 2009 | 11:21 AM
bigbluejk's Avatar
wow. that is crazy. One of those things I have heard of, but never seen before. Teraflex has great customer service.
