Bulging rear Coil
I've had squeaks from the actual sway bar bushings that clamp the bar to the frame. That was solved with some Fluid Film. I just highlight it as another source. If you ever need to track down a rear end squeak, just getting on one side of the tub and rocking the whole jeep back and forth real good usually helps (gets all those suspension components in motion).
EHarris
Because our jeep is at an oddball height we'll be using the JKS version:
https://jksmfg.com/i-19438145-front-...tml%3Fq%3D2031
Perfecto! Thanks for posting the smaller lift model.
EHarris
Yea sometimes in parking lot rain ditches is how I can tell I need new shocks. When they are blown it rocks back and fourth so much I hit my head on the drivers side window. lol
Who/ what are you going with? I'm going down that same road and while there are brands I'd like to pursue, they don't work with my setup. I'm looking at OME's and Fox performance. I'm fortunate enough to get off the highway quite frequently so I can go with a little stiffer shock if necessary.
EHarris
I've had to replace the front shocks 3 times already and I thought the TJM's would last longer than this but have not. Often while driving over calming humps, I can here a whoosh sound coming from the front shocks. with only 37K miles on the current TJMs, I guess I'll have to break down and buy something better. prob Flacons 2.0 with a reserve.
EHarris
OscarMike- yes, that information was for you, but also for future forum members.
Last edited by karls10jk; Feb 11, 2021 at 04:07 AM. Reason: Not personal attack, just info for future
