Bumb Clunk
when i go over a bump at around 30 i heer a big clunk it sounds like something is loose or the axle is hitting the bumb stops
i have a rockhard oil pan, cat and xer case skid
does any one else get this?
no its only in the front only when going over bumps
it sounds 2 part much like the axle is hitting the bump stops but it sounds more metal on metal than that...
stock lift, tires, and axles
check your front sway bar links. there is a good chance that they have come loose - i have seen this happen a lot. also, check your shocks. i have seen where the mounting bolts have come loose and i have seen where the bushing fails and causes a similar noise. being that you are still stock everything, i would start with these things.
