Bumb Clunk
Old Apr 23, 2009 | 04:43 PM
socal4dr's Avatar
Default Bumb Clunk
when i go over a bump at around 30 i heer a big clunk it sounds like something is loose or the axle is hitting the bumb stops
i have a rockhard oil pan, cat and xer case skid
does any one else get this?
Old Apr 23, 2009 | 05:12 PM
wayoflife's Avatar
JK-Forum Founder
a little more info would help out. do you hear this in the front, the rear, all over and do you have any kind of a lift?
Old Apr 23, 2009 | 05:31 PM
Covert_Ops's Avatar
Could this be the clunk in the A pillar that became the clunk from the latches?
Old Apr 23, 2009 | 09:59 PM
socal4dr's Avatar
no its only in the front only when going over bumps
it sounds 2 part much like the axle is hitting the bump stops but it sounds more metal on metal than that...
stock lift, tires, and axles
Old Apr 23, 2009 | 10:07 PM
wayoflife's Avatar
JK-Forum Founder
check your front sway bar links. there is a good chance that they have come loose - i have seen this happen a lot. also, check your shocks. i have seen where the mounting bolts have come loose and i have seen where the bushing fails and causes a similar noise. being that you are still stock everything, i would start with these things.
Old Apr 23, 2009 | 10:36 PM
socal4dr's Avatar
ok cool ill check in the morniing
Old Apr 24, 2009 | 03:45 AM
Willy's Avatar
Check if your front bracket on your skid plate ia coming into contact with your front driveshaft. You would see rub marks on the bracket, and or driveshaft/yoke.
