Bump stops
Old Jan 25, 2011 | 09:20 AM
debsJK's Avatar
Default Bump stops
Suggestions on which bump stops to get? The factory ones just aren't doing it and I need to get them soon.
Old Jan 25, 2011 | 09:27 AM
GON WHLN's Avatar
Teraflex front/rear bumpstops. No welding and they look good. Please their $40 a pair.
Ofcourse this all depends on how much lift/travel you have
Old Jan 25, 2011 | 09:37 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Or a set of SpeedBumps!
Old Jan 25, 2011 | 09:42 AM
Davesrb's Avatar
That's the route I took!
Davesrb
Old Jan 25, 2011 | 09:44 AM
debsJK's Avatar
I have 35s with a 2"suspension and about a 2" body lift. Are the teraflex adjustable?
Old Jan 25, 2011 | 09:51 AM
Davesrb's Avatar
For the regular bump stops, IDK.
I ordered a 2.5 inch ift and the Speedbumps for a 2.5 inch lift. The Speedbumps come with collars that let you adjust them if you need more bump stop.
Old Jan 25, 2011 | 09:54 AM
debsJK's Avatar
ok I love adding stuff to my Jeep, but for $900 I can get a ton of other stuff. What about good INEXPENSIVE bump stops?
Old Jan 25, 2011 | 10:29 AM
debsJK's Avatar
I have pocket flares and I rub alot. Busted the plastic where the screws hold it on when I went wheeling last (I was disconnected.) Trying not to do that again and it was suggested that I get bumpstops. So here I am
Old Jan 25, 2011 | 12:41 PM
untold's Avatar
hey debs, planman ideas for bumpstop are not that bad. you can easy do that by ur self and for the cheap. if u can't( I think u can), the top rock will help with no question asked.
Ryan
Old Jan 25, 2011 | 12:51 PM
AussieTom's Avatar
Default Bump Stops
For the front, you can also use the plastic board used on the back of small boats that the outboard motor bolts to, just cut 2.5" disks, and use similar to hockey pucks. The benefit of using disks is that u can slip them in between your coils if u need to add more, rather than removing your coils to add a larger one.
U can use the same plastic board from the rears as well, and stack them, or use RHS section such as trailer drawbar, which you can buy offcuts in various sizes to suit.
Planman - what about your shocks. I would think you need at lease 2" bumpstops for your OME LT shocks.
