Bump stops
Old Jan 25, 2011 | 12:56 PM
rinkishJK's Avatar
ive had hockey pucks on mine for months and they work fine.. and at 1.30 a piece there quite good on the wallet..
i used an epoxy. i got 2 at each corner plus the stockers..
planman's idea is awesome!
Old Jan 25, 2011 | 01:14 PM
debsJK's Avatar
I've heard the hockey puck idea. Just saw your write up... it's worth a try! THANKS
basically I need 2 hockey pucks per spring...right?
Old Jan 25, 2011 | 01:21 PM
Evolution's Avatar
Sponsoring Vendor
Wow Hockey Pucks... I like that DIY idea.
If hockey pucks wont do it for you...
Front: $47.99
Available in 2” height (~35” Tire Clearance or 37" tires with aftermarket flat or cut factory fenders) and 3” height (~37” Tire Clearance)
Rear: $79.99
Available in 3” height (~35” Tire Clearance or 37” with flat or cut factory fenders) and 4” height (~37” Tire Clearance)
http://www.offroadevolution.com/stor...RONT-BUMPSTOPS
Old Jan 26, 2011 | 10:59 AM
debsJK's Avatar
Hockey pucks on sale at Target $0.98 It's a start!
Old Jan 26, 2011 | 11:20 AM
Monte417's Avatar
x2 Is it 2 pucks for both the front and rear?
Old Feb 6, 2011 | 10:31 AM
nkijkuit's Avatar
How about these (http://www.northridge4x4.com/proddet...prod=TF-953800) Terraflex Bumpstop.
Can they be installed without removing the coils (I don't have a compress-thingy)
Old Feb 6, 2011 | 12:27 PM
nkijkuit's Avatar
Is there a solution without having to remove the coils. Maybe the hockey puck with glue rather using a bolt?
Old Feb 6, 2011 | 08:05 PM
chuck_unleaded's Avatar
teraflex bump stops
Old Feb 7, 2011 | 06:43 AM
nkijkuit's Avatar
Originally Posted by chuck_unleaded
teraflex bump stops
You mean they can be used without having to remove the coils?
Old Feb 7, 2011 | 06:53 AM
stlfan06's Avatar
As far as I know, ALL front bumpstop installations require removing the coils...since they sit inside the coil. Rear bumpstops sit outside the coils, so you can install them anytime.
