Bump stops?
Old Dec 24, 2012 | 02:53 AM
hoghd06's Avatar
Default Bump stops?
I'm having the rock krawler 3.5" mid arm installed this weekend. I'm not sure if bump stops should be installed or if they are necessary. Advice would be appreciated
Old Dec 24, 2012 | 02:59 AM
Jethro0417's Avatar
Shoot a pm to their Rep on here with the lift size, tire size you'll be running and if you have stock fenders or flat fenders and they can tell you what size BS you need.
Old Dec 24, 2012 | 03:02 AM
hoghd06's Avatar
Ok thanks. How exactly do I locate the rock krawler rep?
Old Dec 24, 2012 | 03:03 AM
rtguy1's Avatar
the installer needs to cycle the suspension with the tires on and springs out to determine bumpstop height. no other way if u want "max" travel
Old Dec 24, 2012 | 03:21 AM
hoghd06's Avatar
This is the setup I'm doing. This is directly from rk website. Stock flares, bilstein 5100's, and 35" Goodyear duratracs.
Old Jan 6, 2013 | 02:44 PM
TonyJeep75's Avatar
Find an answer? I'm in the same boat.
Old Jan 6, 2013 | 06:39 PM
hoghd06's Avatar
I ended up putting in 2" bumpstops per rock krawler when running 35's and oem fenders.
Old Jan 6, 2013 | 07:10 PM
devwil68's Avatar
I am going to be installing the same kit, but running 37s. I know it needs to be flexed out, but I will be running the teraflex 3" bump stops. Anybody have any thoughts on that?
Old Jan 6, 2013 | 07:24 PM
hoghd06's Avatar
I called rock krawler directly. The numbers on the website. They have techs dedicated to their products. You can't go wrong calling them just tell them your exact setup and go from there
Old Jan 6, 2013 | 07:55 PM
TonyJeep75's Avatar
Thanks man. I'm going to get those, a steering stabilizer, and a front drive shaft and then it should be complete. I'm thinking 600 bucks.
