Bump stops needed with Rubi spring swap?
Old May 18, 2013 | 05:29 PM
glock-n-roll's Avatar
Default Bump stops needed with Rubi spring swap?
I installed some 18/59 springs as well as Rubi take off shocks. I gained a solid 2" in the front and about 1 1/2" in the back. Do I need to think about bump stops at this point? I have a URE trip coming up so it is going to get flexed. Thanks!
Old May 18, 2013 | 05:31 PM
4W-Jive's Avatar
Not at all. Enjoy.
Old May 20, 2013 | 08:50 AM
All righty then! That is good news to me! Thank you!
Old May 20, 2013 | 10:22 AM
Rob 12B1P's Avatar
You might if you go to a larger tire otherwise you should be fine.
