Bumper Surgery
Old 01-04-2007, 08:34 PM
nickc's Avatar
or just us the sawzall and then sand or file it down
Old 01-04-2007, 08:56 PM
dhoffroad's Avatar
got any info on that jeep , links or pics ??
Old 01-04-2007, 09:44 PM
Rubimon's Avatar
If it were me, I'd probably take my time pre-scoring it heavily with a utility knife and then hacking it off with a sawzall that had a fine tooth metal cutting blade. I have cut through vehicle plastic using a cutoff wheel on a dremel and although it works, it tends to melt the plastic and make a mess.
I agree! Tape it with masking tape(wide enough to protect the surface from the saw), draw a line where you want to cut, score it with a knife, and then cut it just outside of your scored line. I would use a fine tooth blade on a sabre saw (jig saw) preferably one with variable speed so you can go as slow as you need. Then I would take a belt sander belt wrapped around a block of wood and grind it to your line. (Don't use a power tool for this as you will develop too much heat and make a mess of things.)Maybe start with a rough belt and finish with a finer one.
Lastly, I might try a quick wisping of the edge with a torch to then smooth out your grinding lines. I would practice this on the cut-off piece first to see how it goes.
Oh, I would do all of this with the bumper off of the vehicle.
Old 01-04-2007, 11:01 PM
Nefarious's Avatar
It's the new Rock Krawler rubicon to showcase their new lift kit. Hipper just posted pics of it in another thread.
Old 01-04-2007, 11:57 PM
biglynny's Avatar
Default Sweet
I'm a fan of the stubby bumper look. I'm waiting for the PJ stubby with lights and room for a winch. Hipper's Jeep pictured is one bad lookin' dog.
ID:	460491   Click image for larger version
ID:	460492   Click image for larger version
ID:	460493   Click image for larger version
ID:	460494   Click image for larger version
ID:	462928   Click image for larger version
ID:	512669   Click image for larger version
ID:	525405   Click image for larger version
ID:	525406   Click image for larger version
ID:	559343   Click image for larger version
ID:	559344   Click image for larger version
ID:	559345   Click image for larger version
ID:	559346   Click image for larger version
Old 01-05-2007, 07:09 AM
jeepinoutwest's Avatar
Ok ive been thinkin about this a bit. I agree no power tools. First I wouldn't cut it right to the crush can line. I would probably go an inch off of the crush can. Then use masking tape to get the right line, then score the line with a utility knife, then use a hack saw (the small kind that just hold one end of the blade), then sand with a fine grit, then to top it off I think I would find a material like what they use for jeep door edge guard which can be glued and press fit over the cut to form an almost factory job.
ID:	464828   Click image for larger version
ID:	464829   Click image for larger version
ID:	464830   Click image for larger version
ID:	464831   Click image for larger version
ID:	464833   Click image for larger version
ID:	467768   Click image for larger version
ID:	467771   Click image for larger version
ID:	467773   Click image for larger version
Old 01-05-2007, 10:31 AM
Ok I learned three more things. On the front bumper if you cut within 8" or so of the crush can you also have to cut through a psuedo steel bumper. If you cut only 10" or so off each side you will cut just plastic. (not an issue on rear bumper its all plastic, but would have to remove bolted on metal supports)Also, I have a feelin the blow mold bumper is hollow, meaning if you cut it you will have what would look similiar to a slice of an empty calzone. Lastly, The plastic remaining will be approximately .5" thick so my idea of using door edge molding will not work but something similiar of a thicker degree would and cover the empty space inside the bumper.
ID:	467532   Click image for larger version
ID:	467533   Click image for larger version
ID:	467534   Click image for larger version
ID:	467535   Click image for larger version
ID:	467856   Click image for larger version
ID:	467857   Click image for larger version
ID:	467858   Click image for larger version
ID:	467859   Click image for larger version
Old 01-05-2007, 12:12 PM
Phishjeep's Avatar
I think the peiece you are referring to is a tough ABS plastic. Not even aluminum that thick would flex when you pushed against the end of it. I pulled my air dam off today, and started looking at the possibility of stubbifying the stock bumper.
ID:	471429   Click image for larger version
ID:	471430   Click image for larger version
ID:	471431   Click image for larger version
ID:	471432   Click image for larger version
Old 01-05-2007, 12:15 PM
2K1TJ's Avatar
Emty calzone= bad times :sad:
I wish there were some close-up pics of that bumper. Anybody got a link to any?
ID:	471638   Click image for larger version
ID:	471639   Click image for larger version
ID:	471640   Click image for larger version
ID:	471641   Click image for larger version
Quick Reply: Bumper Surgery
