C gussets AND sleeves???
Whoa is that a bad word???
Anyone hear of the S y n n e r g y kits for C gussets? ANY GOOD?? Thx
Originally Posted by brink2177
I had mine done a few months ago by a local shop and it only took him about an hour to get them welded on.
I did mine a few months ago. i approached it as a weekend project, but that include the lift too and I did it myself with an occasional helping hand from my wife.
3 hrs - Removing axle.
2 hrs - install c-gussets
2 hrs - drilling 22 holes in the axle tubes
2 hrs - welding in sleeves
3 hrs installing axle
You can find where some people install it all with the axle on the jeep. I removed it to avoid all the challenges of welding upside down under the vehicle.
The guys at ORW said it would be about 8 hours for them to do it.
It can be frustrating cause I want it done right.
Originally Posted by awesomo
Forget the sleeves...get a backbone truss instead. Eliminates the need to remove the axle.
Thx
Does mostly everyone AGREE that for a Dana30 up front it's best to sleeve and C gusset?
I'm looking at the EVO sleeve and gusset at Northridge4x4....
I want to do top and bottom C gussets for sure does anyone know time wise how many hrs it would take just to C gusset the top and bottom front axle???
And then maybe how many hrs to do BOTH sleeve and gusset for comparison sakes.
Thanks and anyone know if this EVO set is good? Thanks
-Do both top and bottom stiffeners
-Leave the axles and springs attached. All you need to do is remove the tires (obviously).
-Installation will take about 1 1/2 hours with a good experienced welder.
-Use a moist rag to keep key components cooled and protected during welding.
-Start on the driver side, do one inch of weld to one section of the top bracket then make another 1 inch weld on the lower bracket. Then move to the passenger side and make another 1 inch weld on the top and then the bottom bracket. Move back to the driverside and repeat until welding is completed. Use the moist rag to cool as you weld.
This is the method I used and it worked perfect. No damage to anything.
PM with any questions.
Ya when I got my sleeves, C2s, and skids done we didn't pull axle. Just make sure you take time with the welding so you don't overheat the ball joints or anything else. ALSO trusses are known to warp axles when welding on.. That's why 90+% tell you to sleeve not truss
