Caliper problem
Old Apr 26, 2014 | 06:31 AM
headrock's Avatar
Default Caliper problem
Driving down the road today I had a bad pull to the right. When I finally had a chance to pull over, I had the burning brakes smell and some smoke coming from the front passenger side caliper. I let things cool off and made my way home with less pull to the right. When things cooled down, I jacked up the front passenger side and pulled the tire. The rotor would spin without much effort. I had a friend pump the brakes and the rotor would only stop when the brakes were applied. My guess is the caliper is on its way out and not completely frozen up yet. I don't think the brake hose is bad. I put hawk pads in less than a year ago as well. If the pads are shot on the passenger side as well, can I just replace the pads on that side or do I need to do the driver side as well? The pads looked ok on the passenger side but I didn't pull them off yet so I'm hoping they are ok. Any caliper brand I should go with or just the typical parts store brand? I will be doing both front calipers if this is the culprit on the passenger side. As always, any info is very much appreciated.
Old Apr 27, 2014 | 09:56 AM
F200's Avatar
You may want to check the sliding pin/bolts on the calipers. May just be one or both of those hanging up. If so, you can work them loose, clean and lube and you may be good to go.
CM
Old Apr 27, 2014 | 10:12 AM
zacs08jk's Avatar
I have less than 50k on my 08 jku, and just last week I had to replace my 2nd caliper! The first one was a rear and now the front. It sucks that these calipers are failing so fasg
Old May 1, 2014 | 06:00 AM
Spaf's Avatar
55K and a second caliper replacement for me last week. I've never done my own brake work but at this rate I think I better learn to.
Old May 1, 2014 | 07:08 AM
bmartin4's Avatar
It happened to me and it was the piston in the caliper that seized up. Just replace your caliper....although your rotor my need to be replaced now too
Old May 1, 2014 | 07:14 AM
PG-JKU's Avatar
Rear passenger caliper for me last week. Smoke was coming out from the wheel well.
160,000 km so whatever.
