can caster issues cause death wobble?
Yes you just need front lower control arms to adjust your castor.
23" is usually a good starting point with that lift height.
The EVOs can be adjusted while staying fully installed on your JK to fine tune the castor. No removal of one end required to adjust the length.
I don't know of any place of the C where you'll be able to find an accurate angle. A much better place is the pinion flange. Stock angles are caster at 4* and the pinion up at 2*. If your earlier 0* measurement is correct, your pinion should now be at 6*.
http://project-jk.com/wpg2?g2_itemId=28641
Here is the writeup.
http://project-jk.com/jeep-jk-write-...-end-alignment
When I placed the angle finder on the same spot as in photo above it said 0. I didnt put it on ground but it is very level part of driveway so I think that is fairly close measurement. Is there a better way to do this?
Assumption is that your kit is installed correctly and all torque to spec.....
I say caster angle is critical ...front uppers allowed me to adjust and I found that was the one 'adjustment' which took care of DW(after a TeraFlex 4.5" lift
) . I specifically test drove after the lift install ...to experience DW ...then adjusted away from it.
my lowers are set to 24" eye to eye, and uppers are 19.5". i have ome hd springs n 1"spacer upfront... my algle reads 5 both sides.
This is why I prefer to use the pinion flange as a measuring point. 5* is more than stock. Have you actually turned your pinion down from stock?
