can caster issues cause death wobble?
The pinion measures about 3, so there is a 2 degree diff, which I think u want... If u look at it, it is pretty close to level, slightly down refering to the pinion flange.I have no driveshaft vibe issues at all. I can go almost 1/2" longer on the arms before I get a vibe. I have gone that far, and the gauge will read closer to 8 ish then. Drives good, but not with the vibes. The settings I mentioned work for my lift.
There is NO one-size-fits-all magic number. Experiment until you have a pinion angle and a caster angle you can live with.
No. The length is a 'starting' measurement. After you install the new arms, check the caster. If it is too low, lengthen the arms some more and re-measure. If the caster is still too low, lengthen the arms again and re-measure.
I have heard some people replace the stock track bar bolts with 9/16 shouldered bolts since the r a little bigger yet still fit. Anyone try thus to cure Dw?
Update: It was the trackbar giving me all the problems. My JKS trackbar which was less than a year old went bad. David from Northridge hooked me up with a new one and Death wobble is gone. Went for a drive and hit the same spots that was sending me into DW hell for days and no problems at all. Thank you and again Northridge. Still have yet to put Clayton arms on to correct caster so that will make it ride nicer but had nothing to do with DW.
