Can I re-use the factory LSD?
Old Jul 7, 2010 | 10:40 AM
Adam3612's Avatar
Default Can I re-use the factory LSD?
I'm swapping out the 3.21's for 4.10's, from what information i've been able to gather I should be able to re-use the factory LSD in the D44, is this correct?
Old Jul 7, 2010 | 12:41 PM
BlackNorthernJK's Avatar
You absolutely can in the rear D44 yes. ....and if you, or others were looking to toss it and get something else, you require a 3.73 and DOWN unit to accomodate the thicker JK 44 ring gear.
Old Jul 7, 2010 | 01:25 PM
Adam3612's Avatar
Ok so stock LSD currently with 3.21's CAN be re-used with new 4.10's? Excellent, thanks man I appreciate your help.
