Can you look at my clutch and flywheel? Toast?
Hi guys, I have a 2012 JK and have ruined my second clutch, Jeep only has 20,000 mikes, I'm a very slow learner, went through mud again and pushed clutch in (didn't think I was in too deep). After flushing out the clutch after the mud hole it stopped disengaging so I had to tear it down.
Anyways, here're some pics. I already bought a new CF TOB but do you think I need a new clutch? New flywheel? Can 2012 flywheels be turned? There are some heat marks on the fly wheel with some small grooves. Also the fingers on the clutch plate are bent a little. Also does it look like the TOB was partially seized and turning (there are marks on the fingers) causing it to not disengage? I guess the caked on mud didn't he;p either...
I'd rather not buy a new clutch, money is so tight right now, especially don't want to buy a new fly wheel, but I guessing I need to :(, what do you guys think?
Plenty of hot spots on that flywheel. Definitely have that surfaced. Disclaimer: I've completed a ton of clutch jobs, but none on our '12s so while I don't unequivocally know the answer to "can it be surfaced?" it certainly appears it can be and I've not ever seen one that cannot.
The most important component in the equation you do not have pictured. From the appearance of the flywheel, there's been a ton of slippage which means the disc is likely glazed ("lubricated" by the mud) requiring replacement and it makes no sense to replace the disc, machine the flywheel and not replace the pressure plate, TOB AND pilot bearing.
I know it's not the answer you want to hear if $'s tight, but any other way is influencing another tear down.
I feel your pain, '12 JKUR with 40k, time for a new clutch, pressure plate, TOB and flywheel. Dealer wants $1900. Not paying that price. :/
This space intentionally left blank
I ended up just changing the TOB and just cleaning the other stuff (soaked the pressure plate in water/simple green and flushed the crap out if it)
Seems to be running fine now so thank god. I don't want to do that again.
Lol, got the tranny lined up first try installing it then realized I forgot to touque the pressure plate bolts. Had to unbolt and remove the tranny. The second try putting the tranny back on on took me 3 agonizing hours, just would not line up the second time.
I actually ordered one from Amazon (had an extremely had time finding one). Finally got the one from Amazon and it was the wrong one. I couldn't find a place anywhere on this planet that had one for my Jeep. Had to buy a cheesy universal kit the day of the install. Which doesn't give you an exact fit. I think the 2nd time I put the tranny back on it probably off centered the disk a bit which is why the 2nd time was so hard.
Now I just found out my front diff is trashed. All that work on the clutch now the diff is gone :( My fault though I guess.
