Caster angle help
Old Jul 6, 2011 | 07:59 PM
jeeeep's Avatar
Default Caster angle help
installed 3.5" lift and getting ready to set caster, couple of items I need help with:
1. tires are 35" have not arrive yet, can I set the caster with stock wheels, drive it to tire shop and let them install tires or should I pick up the tires install them then set caster?
2. Do I set caster on each side? research isn't clear if I should only set one side and adjust the opposite arms to fit or do I set caster on one side, fit the arms then set caster on opposite side and fit the arms - confused!
Thanks for the help -
2010 Rubicon 4dr. unlimited
Old Jul 6, 2011 | 08:19 PM
jeeeep's Avatar
Default light bulb moment
I just had the light bulb go off regarding question 2 - so no help needed there. question 1 could use some input. thanks
Old Jul 6, 2011 | 08:46 PM
MuddRat's Avatar
Do you have adj arms? What lift are we talking about here?
I see you went with Clayton (SWEET).
Do you have all 4 arms in front?
Old Jul 6, 2011 | 10:11 PM
nthinuf's Avatar
Set your caster for the lift height, before or after the new tires doesn't matter. You may want to adjust the Toe a bit for the new tires, but drive it first before messing with it.
Go down to the Write-Ups area. Stickied at the top, you will find an Index. In both the Steering and the Troubleshooting sections, there is a DIY Alignment writeup with all the info you will need.
Old Jul 7, 2011 | 07:51 PM
jeeeep's Avatar
yes - all 4 arms
Old Jul 7, 2011 | 07:55 PM
jeeeep's Avatar
thanks, still a little confused as to which way the angle should rotate? so the diff moving upward = positive angle or?
Old Jul 7, 2011 | 08:01 PM
nthinuf's Avatar
The pinion moving up lowers caster
Pinion moving down raises caster
Front Upper ca's:
Lengthen to raise caster
Shorten to lower caster
Front Lower ca's:
Lengthen to lower caster
Shorten to raise caster
Old Jul 7, 2011 | 08:02 PM
Dynatrac's Avatar
Sponsoring Manufacturer
When you are rotating the pinion up you are decreasing the caster angle.
Old Jul 7, 2011 | 08:28 PM
jeeeep's Avatar
Default THanks everyone!
Thanks - can't wait to tackle trails I passed on with stock setup!
