Caster angle help
installed 3.5" lift and getting ready to set caster, couple of items I need help with:
1. tires are 35" have not arrive yet, can I set the caster with stock wheels, drive it to tire shop and let them install tires or should I pick up the tires install them then set caster?
2. Do I set caster on each side? research isn't clear if I should only set one side and adjust the opposite arms to fit or do I set caster on one side, fit the arms then set caster on opposite side and fit the arms - confused!
Thanks for the help -
2010 Rubicon 4dr. unlimited
Do you have adj arms? What lift are we talking about here?
I see you went with Clayton (SWEET).
Do you have all 4 arms in front?
Set your caster for the lift height, before or after the new tires doesn't matter. You may want to adjust the Toe a bit for the new tires, but drive it first before messing with it.
Go down to the Write-Ups area. Stickied at the top, you will find an Index. In both the Steering and the Troubleshooting sections, there is a DIY Alignment writeup with all the info you will need.
The pinion moving up lowers caster
Pinion moving down raises caster
Front Upper ca's:
Lengthen to raise caster
Shorten to lower caster
Front Lower ca's:
Lengthen to lower caster
Shorten to raise caster
Front Upper ca's:
Front Lower ca's:
