Caster and Control Arm Length
If you adjust the 5 links ( 4 CAs and trackbar) randomly or incorrectly, it can lead to binding of the joints during articulation. You just need to be rationale and systematic about adjusting the lengths.
The process in the Alignment Write Up has worked well for many of us.
Regarding the Caster specs, if you can align your wheels to that level of accuracy in your home garage ...
How do you adjust your Camber?
Would it be everyone's opinion that I should make sure that my control arms are of the same length?
If I still drift a bit to the driver side, maybe I should consider an alignment?
Yes, The lower CA's should be the same length and the upper CA's are also the same length. I asume that you know that the uppers will be a different length than the lowers.
Look in the write-up section and review lift kit installs and especially the allignment write-up.
I solved my pull to the right by adjusting the track bar.
An alignment is very easy to do on a jeep, you may want to consider doing it yourself.
I was just looking over the installation guide from teraflex,
it said the driver side should be 23 7/8
and the passenger side should be 24 1/8 on the 4 door
it also said the front lower passenger and driver control arms are different to eliminate the tendency of the JK's to pull to the right
That's kind of interesting, so Teraflex is advising a .25" longer wheelbase on the passenger side. That would induce a constant slow turn to the left. Just curious, does the lift that you got (with the instructions) include an adjustable track bar?
No, it doesn't. It's to accomadate for the crown in the roads here. Just like I spoke about earlier, and had everyone basically tell me I was an idiot.
...Got my control arms (havent installed my lift yet),but that's what the TF instructions recommends...
I just happen to find teraflex installation guide first.
