Caster Question
Old Jul 26, 2007 | 03:49 PM
CLACKEY(_!_)'s Avatar
Originally Posted by Huntr
how did you adjust the caster?
Fortunately I have a BADA$$ lift. Full Traction Ultimate 3," and it came with adjustable arms.
Old Jul 26, 2007 | 04:02 PM
gcg's Avatar
gcg
If the stock arms are not adjustable how is this done?
The stock arms don't allow for adjustment. In order to adjust your castor you will have to upgrade to adjustable arms. There's also the "cam bolt" approach that's been mentioned. This allows you to adjust the castor without changing out the arms themselves. It basically allows you to adjust the point at which the arm attaches to the axle rather than adjust the length of the arm itself.
I don't have any experience with these myself. Another post was discouraging their use. Although there is an expense to upgrading to adjustable arms, once it's done you'll have a stronger suspension and you'll be able to experiment with different castor settings relatively easily.
Old Jul 26, 2007 | 04:04 PM
dougolupski's Avatar
On a stock vehicle it cannot be done without changing to adj control arms, adj ball joints, or cam pins ( of which I completely agree with wayoflife). The factory suspension is designed to be with a spec every time so they don't worry about making adjustments. Just bolt every thing on set toe and away they go. I personally opt for lower arms first due to the fact the axel moves inward towards the middle of the car with fixed arms creating a shorter wheel base.
Old Jul 26, 2007 | 04:48 PM
Huntr's Avatar
great info. thanks! so from what I understand I only need to do either the front top or the front bottom control arms-but not both. And it doesn't matter which one I do is that right?
Old Jul 26, 2007 | 05:05 PM
gcg's Avatar
gcg
Yes, you could do just the uppers or just the lowers. However, if you're going to go to the trouble to do it, you might consider just getting all 4. Two of them would probably be fixed length and the other two adjustable. That way you can get everything installed and all your alignment stuff done and won't have to worry about upgrading the remaining stock arms later. The after market arms are generally stronger than the stock ones.
Nope doesn't matter. There is an advantage to both though. If you wheel real heavy and need articulation the aftermarket arms with flex joints, spherical joints, or johnny joints flex way better than the stock arms. The rubber bushings in the stock arms like to bind up a bit while the above joints flex real easy. Down side to them is maintinence and vibration. Since it's metal to metal you can feel the vribration and bumps a little more than with rubber. The other option is to look at arms that are rubber at one end and spherical at the other.
Edit: all of what gcg said is also true and a bonus
Old Jul 26, 2007 | 05:15 PM
Huntr's Avatar
i would love to do both but $$$. looking at 250-300 for parts and who knows for labor. i don't do a lot of real rough stuff. my main concern is to just make it feel a little safer and easier to drive. If I can get away with two I think I will.
Old Jul 26, 2007 | 05:35 PM
BLKRuby's Avatar
You can install the arms yourself no problem!
Old Jul 26, 2007 | 05:56 PM
muddpuppy01's Avatar
were are you guys measuring at on the spindle to get your measurements I know I need to do mine but was not sure about the process to do it
Old Jul 26, 2007 | 06:25 PM
Huntr's Avatar
I have not done one before so once you get it back on do you take it to an alignment shop to have it adjusted?
