Caster Question
Old Apr 19, 2013 | 02:24 PM
jeeeep's Avatar
have you taken an angle finder and checked your axle caster? Here's a great write-up on how to do this:
Basic Do-it-Yourself Jeep JK Wrangler Front End Alignment
Old Apr 19, 2013 | 09:21 PM
MidwestRubi's Avatar
Veteran: Marine Corp
Originally Posted by MikeMefford
I recently had a 2.5" Max Travel Lift installed on my 2013 JKU. When I went and picked it up they showed me the alignment specs and everything was in the green, caster angles were close to each other. As I drove it the next couple days I noticed it pulled driver side, so I took it back and they made some adjustments. Now my caster specs are 4.4 Driver and 5.0 Passenger and it still has a slight pull to the drivers side. My questions is are the caster angles suppose to match or are my acceptable? Thanks
What's your rear Track? it should say on the sheet they gave you.
i lifted my 2 door 3.5 in and the track bar bracket i got with my kit was crap, so my rear track is 0.51 degree's out to the passenger, which is giving me me a pull to the drivers side, i ordered a different track bar bracket, if that doesn't help, i'll get some adj rear lower control arms
I did that alignment myself, so i took the extra time too get my front toe and steer ahead perfect, but with the rear track out your rear axle is trying to basically make you drive sideways down the road, each case is diff so this might not help, just thought i'd share
