Centerforce Clutch
Originally Posted by Acer343
Where would I find the master for the clutch?
Jeep is put back together. I have one electrical issue to run down and a vibration to figure out. Otherwise the install is done. I'll try I get the write up cleaned up and posted early next week.
I had a Centerforce clutch in my '89 XJ and it was a piece of really expensive junk. I had to have it replaced within 2 months and then the replacement failed a month after that! I had a stock clutch that lasted me 3 years (until I sold the XJ) without any issues after that. I will never go back to Centerforce in any of my vehicles.
Just a heads-up - I tried running a Centerforce on my diesel truck and HUGE mistake. Same principle that caused it to be a problem in my Diesel applies here: Namely, the Centerforce requires a good bit of centrifugal (sp?) force to make those slider weights fully engage. In other words: for a centerforce clutch to grip fully HIGH RPMs ARE REQUIRED. This is a problem in Diesels (low RPMs compared to gassers) and rock crawling or 4 wheeling applications. That's my opinion, but also my experience.
Originally Posted by BadPunkin
It is my understanding that you are right about that model of clutch. The JK however takes the dual friction which I have been lead to believe works differently. I only have 60 miles on the new clutch, but can say it is very grabby at low rpms. I find myself needing more gas off the line to I overcome the initial grab.
