Ceramic Beads for Tire Balancing
Old Jul 25, 2007 | 06:19 AM
jsmoriss's Avatar
Thumbs up Ceramic Beads for Tire Balancing
I've been using Innovative Balancing's (innovativebalancing.com) ceramic beads in my 33" Toyos for a few weeks now (8oz per tire for a 10 ply 33" tire), and I gotta say, they do what they claim to do. The beads were a real pain to put into the tire though. I went through the valve (instead of the pouch method), and it took about 10-15 mins per tire. Eventually I worked out a system - instead of pouring slowly through the tube, I pushed the bottle into the tube and just squeezed the bottle in & out. It sucked air out of the tire and then pushed in the beads, sucked air, pushed beads, etc. It worked a little faster/easier than pouring slowly.
js.
Old Jul 25, 2007 | 06:23 AM
Theresonlyonejeep's Avatar
js.
why are you having problems with your 33's?. Who balanced them?. I've never had a prob with mine?
Old Jul 25, 2007 | 06:26 AM
jsmoriss's Avatar
You seem to have mis-understood my message -- the beads are used INSTEAD of lead weights for tire balancing. Most people are not aware of this alternative, so I thought I'd post my experience with 'em -- my _positive_ experience. :-)
js.
Old Jul 25, 2007 | 06:33 AM
Robar's Avatar
I have read about those before and have heard of people using bb's and even golf balls in larger tires to balance the weight. I think the trucking industry started using this method to balance tires first. Not sure on that though.
Old Jul 25, 2007 | 06:51 AM
jsmoriss's Avatar
Originally Posted by BeerMonkey
have you aired down the tires since you put them in? reason i ask is i had a set of tires balanced with the equal crap and it kept clogging up the valve stem when i aired down
You have to replace the valve stems by special 'filtered' stems (sold seperately). I've been playing with the tire pressure (going lower and lower), but haven't aired down yet.
js.
Old Jul 25, 2007 | 07:09 AM
bmcollier's Avatar
https://www.jk-forum.com/forums/show...tire+balancing
Wheee!!! I feel like a mod!
Anyway, I recently replaced my lead clip weights with tape weights for aesthetics. I had considered the beads, but there was a not so positive experience on the other thread. Glad it is working for you, it sounds like an interesting alternative.
Old Jul 25, 2007 | 07:39 AM
HappyCurmudgeon's Avatar
Eternal ***erator
Originally Posted by bmcollier
[snip]
[snip]
Don't worry, the lobotomy scars will heal up in a few weeks.
In the meantime, i dont have these in my Jeep, but i do run them in the tires on my dirtbike, they work excellent at speed, but do nothing up to about 20~30ish mph. (not that it matters much, i rarely ride in that speed range anyhow)
