Chalk test question
Old Nov 19, 2013 | 11:40 PM
BadBarret's Avatar
Default Chalk test question
Recently had 35" tires put on my JK and wanted to do the chalk test so I could find the best psi to run in them. My question, and forgive me if it's a dumb question, is does it matter if the tire is cold vs being warm. It's currently about 23 degrees here in WNY. Wasn't sure if it being so could would affect anything. Thanks for the help!
Old Nov 20, 2013 | 02:38 AM
Smashboogie 4x4's Avatar
Former Vendor
Pressures will change with temperature of the tire. The amount of pressure difference is pretty minimal under normal operating conditions. So I wouldn't be to concerned.
Old Nov 20, 2013 | 06:27 AM
DadsCJ's Avatar
After the test when it tells you what pressure to run, it won't matter what the temp is as long as that pressure is maintained in the tire.
The presures will go/up down but you just adjust as necessary.
Old Nov 20, 2013 | 07:17 AM
aircrew423's Avatar
Post some pics of the process I'd like to maybe do this one day.
Old Nov 20, 2013 | 04:44 PM
Ryan0260's Avatar
I would test them cold.
Old Nov 20, 2013 | 06:43 PM
soberbyker's Avatar
http://www.youtube.com/watch?v=ojGsavK0Uwc
Old Nov 20, 2013 | 07:25 PM
aircrew423's Avatar
Well look at that, pretty simple. Thanks for the video
Old Nov 23, 2013 | 09:35 PM
BadBarret's Avatar
Well I was going to do the chalk test today however we got some snow and my Jeep sits outside so my tires would be wet when I attempted it. So I sat there thinking and would it be the same if my tires were wet and I drove over a dry surface and looked at the tracks it made?
Old Nov 24, 2013 | 06:46 AM
BadBarret's Avatar
Must be no lol
Old Nov 24, 2013 | 09:55 AM
stagedtrip's Avatar
No I don't think the tracks will give you quite the same result chaulk will
