Change limited slip to locker
I have a '07 Wrangler X that came equiped with a limited slip rear diff. I am considering adding a locker to the rear and perhaps the Mopar Dana 44 with locker to the front. My question.
Can the rear limited slip be changed out to a locker without modifiying the housing or other parts?
It ain't quite that easy. The Powertrax unit I believe is made for an open differential carrier. He'll need to get the open carrier for the D44 and then it will work.
Powertrax makes a version of their No-Slip lunch box locker to go in LS versions of the D44 but who knows if it will fit the track lok in the JK.
No arguement from me. If I do anything, it's gonna be detroit locker all the way.
You are assuming that he currently has 4.1 gearing. If he doesn't he would have to regear the front anyway.
I don't know where you are looking but i sure would like to know where you have found a custom jk dana 44 front axle for 2800. The cheapest thing i have found is through currie and its still running around 4000.
