Changing Gears
Old Jun 4, 2011 | 02:15 PM
baz0157's Avatar
Default Changing Gears
Have recently put on my 35's. I was next planing to upgrade my suspension...currently have a 4" Rough Country Lift. However, I'm thinking I should get into changing my gears before I change suspensions.
Any ideas? and advice on what gears to go with?
Old Jun 4, 2011 | 02:28 PM
Battlefrog's Avatar
4.88 - 5.13's
Old Jun 4, 2011 | 02:33 PM
BobonicHonnick's Avatar
If you're running a 4" kit and are planning on going bigger, I'm assuming you're going to run larger tires in the future, 37s perhaps. If that is the case, I would go with 5.13s at the very least, maybe 5.38s. Just depends on what size tire you will be running in the long run.
Old Jun 4, 2011 | 02:39 PM
nthinuf's Avatar
Auto with a D30 up front? 5.38's would give better performance, but from a strength perspective, 5.13's would probably be the better choice.
Old Jun 4, 2011 | 05:49 PM
jagermeister427's Avatar
I just bought my 5:13's... They get installed wed-thur we will see how it goes
Old Jun 4, 2011 | 06:42 PM
baz0157's Avatar
I'm most likely gonna stick with the 35's... It is an auto with a D30 front. Seems like 5.13 is the choice amongst everyone... Looks like I'll be saving up some $$$$ for another project!
sully151's Avatar
Didn't think you could put 5.38's in a Dana 30
Old Jun 4, 2011 | 06:59 PM
nthinuf's Avatar
They are new. Richmond released them not all that long ago.
Old Jun 4, 2011 | 07:05 PM
HIROLLR's Avatar
Had 5.13's installed this week. 35's, 6 speed which had stock 3.21's....
BEST thing ever done to the JK can't believe I suffered through a year with the 3.21's. Absolutely no comparison. I haven't used 6th gear in a long time and 5th occasionally. Now I use them all. Very happy with the swap.
Old Jun 4, 2011 | 07:27 PM
jjt's Avatar
jjt
I've had 35" MTs, a 6 speed and 3.21s for over three years now. I want to install 4.88s very badly.
