A cheap high?
I'm looking for a simple inexpensive lift for the 37 inch wheels i got for my JK. It needs to be high enough to except 37's, upgradable, and functionable to still off road until i can afford better. Please help
My suggestion is too keep saving and do it right the first time. You will end up spending more in the long run if you go cheap to start with. There's also a lot more that you need to consider when going up to 37s besides just a lift.
37s are rough on the steering and stock lockers. If you have a dana 30 you will probably want to sleeve and gusset the front axle. Also gearing starts to play a big factor. Not sure what you have for gears at the moment. I went for a cheap lift at first and its worked out perfectly fine. I have since added a few components it lacked, but i can see where they say save and research first. I should have waited as i am soon looking to get rid of my current lift. I uses a zone offroad lift also if you wanted to look that route.
