Check engine after dead battery
Old Oct 11, 2013 | 01:22 PM
1tufrubicon's Avatar
Default Check engine after dead battery
I went out of town and got back 5 days later and had dead battery jumped it off and check engine light is on will this go away after battery charges
Old Oct 11, 2013 | 02:03 PM
Jeek.OlllllllO's Avatar
I say you replace the battery! Don't jump it!
I had a battery that died I kept jumping it and after like 5 jumps it started leaking and it got all the paint on the firewall and frame came off! It was a bitch to clean sand and paint!
And yes since your battery is low it will throw a lot of different codes just because its low! I got circuit fan 1 relay, a transmission sensor and low battery but I got a new battery and now I have no codes at all!
Old Oct 11, 2013 | 02:04 PM
Look what I did to be able to get all that acid off! If you have the money and the battery is old I say replace it!
Old Oct 11, 2013 | 02:06 PM
JKBANDIT55's Avatar
ya mine did the same when My battery died. I bought a new one and the light was still on. Went away after a day.
Old Oct 11, 2013 | 02:45 PM
Ryan0260's Avatar
Have the battery load tested. It is probably toast.
Old Oct 11, 2013 | 08:30 PM
dsrtlvr50's Avatar
I just experienced the same thing last week. I recommend replacing the battery. I jumped it one time and it would not hold a charge. My battery was three years old so I figured better to be safe than sorry. So I went to Costco and for $84 I purchased a new one. No more engine light.
